cold start
Old Jan 1, 2018 | 10:10 AM
richardhumphrey82's Avatar
Default cold start
i have a 2016 arctic cat 400 altera that hates to start in the cold whats the best thing i should do to make it easier to start i have battery minder on it all ready but before the bike will start the battery will be dead any ideas
Old Jan 1, 2018 | 11:51 AM
hydrex's Avatar
You might try partially restricting some of the air going into the air filter. My AC 700 started hard this morning at -15F, but so did I.
Old Jan 1, 2018 | 08:10 PM
Kymco 450i's Avatar
Check the choke/enrichment lever to see that it is working properly and check your spark in the cold to be sure it is getting a good blue spark. Should not be a problem starting when cold if everything is set correctly. My UTV started with no issue the other day at -15...it started much quicker than I did.......
Old Jan 5, 2018 | 12:38 AM
scram50's Avatar
if its carburated .. i dont know wich model atvs are efi or not ...
you could open your pilot screw abit to let more fuel in thats what i did a couple weeks ago starts right away now
Old Jan 6, 2018 | 09:47 AM
Zrock's Avatar
Super Quad Patrol
check your plug.. if its hard starting in the cold chances are by now you have fouled up the plug
clayh
Polaris Side by Sides
Jul 30, 2021 07:05 PM
dark_knight8921
Nov 26, 2020 12:06 PM
chewy78
Aug 22, 2016 03:02 PM
86atc250r
Jul 28, 2000 02:40 AM
hunt365@home.com
Jul 3, 2000 11:30 PM
