4wd reverse
Old Jan 13, 2018 | 08:24 AM
turboherb's Avatar
Default 4wd reverse
hi i just got a 2012 sportsman 500 and when you put it in reverse the 4x4 quits working while i try to plow snow.anyone come across this prob. please help. thanks.
Old Jan 13, 2018 | 10:12 AM
Are you pushing the reverse over ride button on the left control switch? Only way to get awd in reverse.
Old Jan 13, 2018 | 10:57 AM
turboherb's Avatar
yes im pushing the overide button
Old Jan 13, 2018 | 12:37 PM
Check that you have voltage on the power wire at the front diff while in reverse with the over ride button pushed in.Extra pair of hands help on this. If you have power, tie into the ground wire and run the wire to a better frame ground. See if the awd then kicks in while in reverse.If it doesn't then you may have a problem in the plastic roll cage that many had problems with. Also with the key off the diff connector should show around 24 ohms on the brown/whire and brown wires. If out of spec the coil plate could be the problem.The manual has other tests as the awd ground still goes through the speedo I believe.It can help you narrow it down to either a wiring problem,problem in the speedo or in the front diff itself.http://polaris-atv.brssm.com/2012-Po...ce-Manual.html
Old Jan 13, 2018 | 06:14 PM
turboherb's Avatar
thanks OPT your always a big help. i will update asap.
Old Jan 13, 2018 | 08:19 PM
Yes keep us updated as this is when they changed the brown/white wire as the power wire when all the previous models had the brown/white as the ground wire for the awd system. This screwed me up when I looked at the the wiring schematic with another poster. Never had a chance to work on the 2012 and later models as the 2011s were the last ones I touched before I retired.
redwood
Apr 5, 2002 03:29 PM
Themudman
Nov 24, 2001 03:20 PM
bigbadSuzuki
Jul 3, 2001 02:52 AM
Timberwolf82
Jan 29, 2000 12:21 PM
