2014 Rubicon sloppy shifter
Old Feb 4, 2018 | 06:32 PM
neilbedwell's Avatar
Default 2014 Rubicon sloppy shifter
My wife has a 2014 Foreman Rubicon. It has about 430 miles on it (yeah, worn out I know). I went out this evening to start it and move it around a bit just to circulate the fluids. I don't ride it much and she hasn't ridden it in a while BUT I noticed the shifter was just super sloppy. From Neutral to Reverse works fine - clicks in positively. From Neutral to Drive is like always - you have to push the button in, push the shifter forward into position and sorta rock the machine until the D lights up on the display. Problem is, once the D lights up, you can take a finger and move the shifter back and forth with very little effort and it will pop right back into Neutral. It'll move about 1/2 to 3/4 of an inch either direction when in "D". It shifts to Low like Reverse - push the button and it clicks right in with a slight rocking of the machine.
Maybe I'm paranoid, but it just seems like D shouldn't be that loose and that easy to pop back into Neutral.
Any thoughts? Any way to tighten it up? I was able to look at the linkage as it connects to the transmission and everything looks tight, the wiggling of the shifter doesn't make the linkage wiggle down by the transmission so I believe the slop is in the top around the shifter itself.
Thanks in advance!
Old Feb 5, 2018 | 02:59 AM
Not sure what you have, the old model had the lever, but when you press it forwards it goes into H or L which is what shows on the dash. I thought the new model was all electric, no levers, except the little reverse/handbrake catch, or is the new 500 auto different to the 420 auto?
elishaman79
Mar 25, 2016 05:03 PM
reconrider88
Jul 17, 2013 09:27 PM
UGLY88
Apr 14, 2006 10:48 AM
Bugs
Feb 28, 2005 07:49 PM
