Lt230s
Old Feb 5, 2018 | 09:21 PM
Suzukilyfe's Avatar
Default Lt230s need help please!!!!!
I just got a 88 lt230s. I adjusted the valves to spec cuz the guy said thats all it needed. Well i went to change the oil and it was way way way over filled! Kind of runny and smelled like gas??????? Any ideas or help would be great!!!!!! This is my first lt ive always wanted one since i was a kid and had the lt250 power wheels lol thanks in advance!
Old Feb 6, 2018 | 03:03 AM
Haven't worked on one, but according to the parts book it has a conventional fuel tap and an overflow pipe from the bottom of the carb, rather than the usual Suzuki vacuum operated tap and no overflow. If it does have an overflow pipe from the bottom of the carb, it is blocked or lifted so the end is above the carb. What has happened is the float needle has stuck, and fuel has started to overflow, if it can't get out the overflow pipe, it runs into the engine or airbox (and then into the engine down the breather pipe). Sometimes a bit of grit can cause the float to stick, this gets out again and the problem doesn't recur, but sometimes you have to remove and change the needle to cure the fault. However it wouldn't cause a sump full of fuel if the overflow was right.
Old Feb 6, 2018 | 05:44 AM
Suzukilyfe's Avatar
Thank you. I took the carb off lastnight it was a mess. Dirty as ever could be. And its missing a few o rings and a spring from one of the set screws. It needs rebuilt somethin fierce. I was just concerned of internal damage!
honda450s
Mar 20, 2007 03:59 PM
RazorbackEXRider
Aug 9, 2002 12:50 AM
RazorbackEXRider
Jan 18, 2002 09:35 PM
GuyRaptor
Apr 12, 2001 11:47 PM
RebelQuadSport
Jan 17, 2001 11:36 PM
