2006 Arctic Cat DVX250 2X4
Old Feb 7, 2018 | 07:44 PM
mrbeggs432's Avatar
Default 2006 Arctic Cat DVX250 2X4
Was given a brand new - well actually a 2006
DVX250 was only driven a few months...Their kids kept crashing so its been sitting in a garage for 10+ yrs.
Anyway charged battery dumped gas and just flushed the carb.
It will not turnover....lights come on...I checked fuses and tugged on a few relays
I hit the start button and nothing...have brakes set...In nuetral...wont turn over or make any sounds......any ideas ???
Old Feb 7, 2018 | 07:53 PM
10 year old battery? If so it's toast.Get a new one.Plus the carb will probably need more than just flushing.I'd thoroughly clean and rebuild one after sitting this long. https://www.ebay.com/itm/Shindy-Carb...daAzwu&vxp=mtr
Old Feb 7, 2018 | 09:11 PM
mrbeggs432's Avatar
I used a battery that was charged and got it tested........havent got far enough to use any gas....new or old....It will not crank over...headlights come on strong....checked the fuse box and pushed/seated any relays I saw whils the fender body was off...........Any other ideas ???????
Old Feb 7, 2018 | 09:49 PM
If you're not getting power to the solenoid small wire,could be a starter relay, neutral diode? or even the start button in the control switch could be a problem. Just a process of elimination. Simple thing like making sure solenoid connections are good,no corrosion especially after sitting 10 years. https://www.arcticcatpartshouse.com/...rness-assembly
Old Feb 9, 2018 | 10:15 AM
alsidsamu's Avatar
Default Must pull clutch in
Even in neutral with the clutch out it hits a switch cutting power. I have a 400dvx and it does the same thing. Just pull the clutch handle in and it will turn over.
Old Feb 9, 2018 | 10:30 AM
scootergptx's Avatar
Supersock
Hired Gun!
250 is an automatic.
Old Feb 9, 2018 | 01:07 PM
mrbeggs432's Avatar
no clutch....its automatic
DeathValleyReaper
Aug 20, 2008 09:47 AM
