1999 artic cat 400 front differential problems???
Old Feb 14, 2018 | 11:18 PM
Garnett Vance's Avatar
Default 1999 artic cat 400 front differential problems???
i have a 1999 artc cat 400 i got off a guy cheap and the front differential is missing and the front axles are gone as well. the guy made some hub bolts to hold the front wheels on and tapped up the knuckle on the front of the motor.to make it ride able. i did not get the front differential with it. does the aartic cat 454 /500 the same or any of the other models?? would i be able to use them and every thing be fine thanks..
Old Feb 15, 2018 | 04:54 PM
hydrex's Avatar
You could compare part numbers with Country Cat. I suspect that they are the same.
cutlass98
Aug 29, 2007 01:43 AM
