1999 Artic cat avt battery problems
Old Aug 25, 2007 | 07:09 PM
cutlass98's Avatar
Default 1999 Artic cat avt battery problems
Does anyone know what could drain the battery on a fourwheeler? We have put on two new batteries on the 4-wheeler, and after a couple of days, it is dead. Something is draining the power, and we have no idea what it could be. Please Help.
Old Aug 26, 2007 | 10:05 AM
buckaroo50's Avatar
You have a short circuit someplace - just where I don't know
Old Aug 27, 2007 | 01:56 PM
Junkman673's Avatar
Probably the voltage regulator/rectifier. Check the voltage output first though.
Old Aug 29, 2007 | 01:43 AM
swampyjunior's Avatar
Cutlas98,
You may want to look at where the wiring harness passes along the base of the steering column. The wires that go to the ignition switch are hot and the harness is prone to rub where they are jammed together there. Anotehr place to look is underneath the instrument cluster.
An easy way to track down a short is with the key off use a volt meter and follow the battery juice from the battery down the hot wire. It could be the winch selinoid or the others already mentioned. But it is definitely a short.
Swampy
MikeyBoyesq
Nov 27, 2020 02:44 PM
toonces
Oct 16, 2019 12:11 PM
Mattius
Jul 11, 2015 10:44 PM
tweeder
Jul 5, 2015 01:57 PM
Jbird4681
Jun 9, 2015 01:59 AM
