Honda 200
Old Apr 9, 2018 | 06:09 PM
204rider's Avatar
Default Honda 200
Hey all, picked up a Honda 200. Been sitting for a while so pulled the carb, soaked it, blew it out, etc.
it will start first pull on choke after it's been sitting for a while, revs up fine on choke but as soon as you take the choke off it dies instantly then won't start up again.
Any ideas?
Old Apr 9, 2018 | 07:01 PM
If you've verified that you have good fuel flow to the carb then it could be jets that are still stopped up and choke would be the only way to keep it running or the carb needle valve may be sticking in the seat not allowing enough fuel to get into the carb to begin with.Therefore the choke would keep it running in that instance also.Still good carb kits out there for these old machines that may solve the problem. Here's one for a 81-82 atc 200 for example.https://www.ebay.com/itm/Shindy-Carb...haaLnQ&vxp=mtr If that's not the year model you have,here's the list of kit numbers.Shindy Products, Inc. - ATV Replacement Parts Plus not a bad idea to check valve clearance. Should be at least a minimum of .003 or so clearance for the intake and exhaust valve,plus a compression test would tell you the condition of the top end.
Old May 10, 2018 | 06:10 PM
artfull dodger's Avatar
My carb was the same way. I soaked it in my soaker can(available at most auto parts store, looks like a gallon can of paint) for 4 hours, then blew all ports clear with a can of carb cleaner. Reassembled, set the adjuster screws to initial start up settings and she fired right up. Took a bit of tuning to get the idle down where it belongs and then tuning the idle mixture so it doesn't load up by running rich, or run hot form running lean. Mike
TimberedWolf250
ATC 3-Wheelers
Nov 11, 2007 10:56 PM
Catterman
Dec 28, 2006 11:51 AM
