No power 2009 polaris trail boss
Old Apr 11, 2018 | 07:19 AM
2009 polaris's Avatar
Default No power 2009 polaris trail boss
Just bought 2009 trail boss 330 with ignition issue. Found fuse link by batt bad(fixed) still nothing . bought new computer still nothing .new ignition switch nothing. Any ideas next?
Jump silonoid and turns over but no lights or fire.
Old Apr 11, 2018 | 07:39 AM
If you replaced the ecm module,ignition switch and fusible link at the battery,sounds like your down the the left control switch. Check the two connectors and wiring leading into the switch for any shorts or connection problems.Spray contact cleaner in the switch crevices and work the emergency kill switch back and forth.Not uncommon to have to replace these switches.
Old Apr 11, 2018 | 08:39 AM
(will do thank you.)
CT250R
Oct 1, 2001 09:34 PM
Templar16
Nov 16, 2000 03:12 AM
