honda rancher problems
Old Apr 21, 2018 | 12:17 PM
stephenwillis's Avatar
Default honda rancher problems
hi i am new to the forum , i have a 2003 Honda rancher 350 . recently rebuilt the top end, it runs but bogs when you give it gas it backfires bad to . i can drive it but it sounds really bad . please help me out if you have any idea what is wrong thanks
Old Apr 25, 2018 | 01:42 AM
Seems a lot like dirt in a jet. Clean the carb out. When you remove the fuel tank you disturb sediment which has settled. Very common to have blocked jets or a leaky float needle after taking the tank off. Backfiring can also be a badly fitted exhaust, make sure the joint between head and pipe isn't leaking.
Old Apr 25, 2018 | 06:02 AM
Default Honda rancher
Well the carburetor was the problem thanks for ya help. Also I just adjusted the valves and they are out of adjustment already do you have any idea why?
Old Apr 26, 2018 | 01:51 AM
Possibly you didn't get the valves right the first time. However if the rebuild was because you overheated the engine and seized it, I have known valve seats to loosen and push rods to "go soft" allowing the ***** to recede into the alloy tubes. Worth keeping an eye on the clearances to see if they keep altering.
Old Apr 26, 2018 | 06:11 AM
Ok thanks for the help
Old Apr 26, 2018 | 06:11 PM
Ok I found out that the valve spring was broken, I just replaced it last week. I think somethings wrong with my cylinder head or just with the valve guides can those be replaced? One of the valve rods are damaged too.
Old Apr 27, 2018 | 01:44 AM
Valve gides can be replaced, but I have never known one to wear badly on a Honda Quad. Most engine machine shops don't replace guides any more, they ream them out and sleeve them. However I have known guides to come loose in the head, this stops the engine, as they eventually jam a valve slightly open.
"One of the valve rods are damaged too"
If this refers to a pushrod, then you will get the valve clearance on that valve altering.
Old May 7, 2018 | 10:14 PM
Yes the rods where bent so I tried to bend them out but I guess they need to be replaced, right?
Old May 7, 2018 | 10:16 PM
Could a damaged rod casuse the valve spring to break. By the way thank you for ya help
Old May 8, 2018 | 01:16 AM
"Could a damaged rod casuse the valve spring to break"
Don't think so. I've never known a Honda valve spring to break, or pushrods to bend. As I wrote earlier, Honda pushrods normally fail because the steel ***** tend to get hammered further into the aluminium tubes. If they are bent, they could be bent back if you are skilled enough, but it is a lot easier just to get new ones.
