Front differential
Old Apr 25, 2018 | 10:44 AM
Swamper32's Avatar
Default Front differential
I have a 2007 sportsman 500x2 efi with adc front differential is almost gone want to rebuild or swap out what years will match up to mine do not care about the adc just want to re and re and play again
Old Apr 25, 2018 | 11:24 AM
Both gear cases with adc and without were used that same year. The one without the adc was 1332578 like this one.https://www.ebay.com/itm/07-2010-Spo...Ba1aXb&vxp=mtr I think even this part number has been updated but Shows it can fit from 2007-2010 models. Here's the breakdown on the gear cases from Partzilla. Models built before 7/17/06 and after were the adc ones. The ones that showed before and after 7/24/06 were without the adc if I remember correctly.Other models may fit also.https://www.partzilla.com/catalog/po...n50af-an-at-ay
Old Apr 25, 2018 | 11:31 AM
Swamper32's Avatar
Mine has adc but could I put an 05 front diff in my 07 or a 2009 in mine don’t care if it has adc or not
Old Apr 25, 2018 | 11:54 AM
Yes it appears that you can. Don't think the driveshafts would be a problem either on either model.2005 gear cases do show different part number drive shafts,but don't know how much of a difference that would make.
Old Apr 25, 2018 | 01:08 PM
Swamper32's Avatar
Ok thanks. One more question just found one off a 08 800 will it match up thanks for all the help
Old Apr 25, 2018 | 01:14 PM
Then you'd be back to the same adc gear case that you have now in the 2007 500 that you want to get away from.. Both show the same part number. https://www.partzilla.com/catalog/po...rcase-mounting
https://www.partzilla.com/catalog/po...earcase1332568 A 2006 and below gearcase possibly would work,but I'm not sure on the driveshafts being a problem or not as I mentioned before. The mounting part isn't the problem. 4 bolts to hold the gear case in place on all of them.
dufferdo
Feb 25, 2000 01:14 AM
bzizzi
Jan 13, 2000 09:09 PM
Andy Bassham
Nov 3, 1999 09:36 PM
