No power to fan fuse
Old Apr 26, 2018 | 11:17 PM
Northroader's Avatar
Default No power to fan fuse
I have a 2005 Honda TRX650FA four wheeler that has no power to the fan fuse. I have replaced the heat sensor on the engine, i have tested the fan and it works. I have added temp power to the blue line on the fan and it works like it is supposed to. I then checked the pink wire on the ignition because in the wiring diagram it shows the pink going directly to the fan fuse. It had no power so i then replaced the ignition switch and it worked fine registering power to the blue fan wire. the next day i checked it again before I assembled it back together and it was as it was before, no power from the ignition switch. I would really like this to work properly without bypassing anything. Any Ideas?
Timothy42666
Apr 7, 2018 05:27 PM
kwatkins
Mar 11, 2018 01:54 PM
merryman
Mar 1, 2018 09:01 AM
Nick Suits
Feb 13, 2018 05:37 PM
jason399
Apr 7, 2005 09:10 PM
