popping noise
Old May 29, 2018 | 03:43 PM
crissy907's Avatar
Default popping noise
this is a 2005 TRX 350 FE 4x4. everytime we start and try to go, it makes a popping noise and tries to die out by itself. what do you think is the issue??
Old May 30, 2018 | 12:42 AM
Does it run better on choke? If so, clean the carb out.
Old May 30, 2018 | 02:55 PM
crissy907's Avatar
yes. we checked the choke, and the choke is not the problem. We might have to change the pistons and rings, because when we are running it there are a lot of oil leaking out of the engine. have to keep filling the engine with oil every three days.
Old May 31, 2018 | 01:57 AM
Piston & ring problems mean the engine burns oil, so lots of blue smoke. Oil leaking out is a blown gasket, oil seal, or cracked casting. You trace where the oil is leaking from, and fix it.
Mudshovel_009
1) Engine problems..
11
Dec 23, 2016 10:19 AM
SusieS
Sep 17, 2016 02:02 AM
200es
Jul 31, 2016 06:21 PM
scoutcamper
Jul 19, 2016 12:59 AM
