Reverse wiring issue
Old May 31, 2018 | 02:23 PM
ROWALKER's Avatar
Default Reverse wiring issue
I have a 2003 Honda 350 Rancher ES. There is an electrical harness/wire that attaches to the lower back side of the engine that controls my ability to shift into reverse. my plug is damaged , does anyone have a Part number for this plug or harness
Old Jun 1, 2018 | 02:24 AM
The wiring sub assembly is shown as attached to the rotary gearchange indicator switch which is inside the rear engine case. Expensive, and a pig to take out and replace. Part number 35759-HN5-A11 if you insist. Far easier to fit a female bullet connector to the old harness. I find standard bullet connectors are a bit big, but can be squeezed slightly so they fit tight on the switch. The rubber boot is quite important as it keeps moisture out, and also is a good tight fit, which helps to keep the bullet in place, save it if you can.
Old Jun 1, 2018 | 09:12 AM
ROWALKER's Avatar
Thanks
tflint162
1) Engine problems..
Jun 17, 2017 02:44 AM
harleysparkplug
Tread Depot
Nov 7, 2012 12:01 PM
Tyler3386
Mar 10, 2007 03:53 AM
hrc200x
Apr 23, 2004 07:32 PM
mudmanatv4x4
Apr 17, 2002 09:59 PM
