2007 Sportsman 500 issues
Old Jun 1, 2018 | 11:00 AM
summit151's Avatar
Default 2007 Sportsman 500 issues
Hello guys. So I had a buddy drop his quad off for me to take a look at it. The first issue was the quad bogs really bad when he starts working it hard. I am assuming this issue is from all the insulation on the gas tank missing and it almost being out of fuel which would cause the fuel to boil? I am planning to top the tank off and see what If I can re create the issue. The other issue I noticed was that the quad was very hard to push even in neutral. So I jacked it up and spun the front tires by hand and they seemed to spin easy. Then I tried the rear and noticed the RH rear tire was very stiff to rotate and would not even spin when I started the atv. I tried in 2x4 and turf mode and AWD? So I pulled the hub off that side and found the bearing was shot and now the axle spins but the LH now spins intermediately and makes a loud popping noise the odd time then engages and spins then stops? And the front tires also always spin even in 2x4? I am very confused on what is going on here any help would be very much appreciated
Old Jun 1, 2018 | 03:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
popping sounds like a bad cv joint, but i'm guessing you would know what that was. I know nothing about the turf mode system but seems I remember reading years ago about issues with them stop or (part time kicking in) working causing symptoms you described but not saying that s it just a thought.
Old Jul 4, 2018 | 03:02 PM
jb.'s Avatar
jb.
my 300 was bogging when running hard as well....turned out to be the etc, to much play in the throttle cable was messing with the etc switch....took the play out,and now it doesnt bog at all
Powerstrokin704
Jan 20, 2018 06:21 PM
06Sportsman500HO
Nov 29, 2017 12:11 PM
Ride on
Jul 16, 2014 12:15 PM
Polaris_500
Jan 19, 2010 02:34 AM
jodaanja
Apr 17, 2009 01:22 PM
