2000 Prairie 300 blowing 5amp fuses
Old Jun 1, 2018 | 01:13 PM
Metricman's Avatar
Default 2000 Prairie 300 blowing 5amp fuses
I keep blowing fuses, and ive covered all exposed wires I’ve seen. Yet when replacing the ignition, there was 2 other lines chewed through. Not w/n the harness. I covered them in tape, but I need to know where they go, as I couldn’t see. As I’m wondering if this is still why I’m blowing the fuse. Would greatly appreciate input and even a photo if you have a Prairie. Thank you
Old Jun 1, 2018 | 02:23 PM
scootergptx's Avatar
Supersock
Hired Gun!
Should be the accessory fuse, if I remember right. From what I've read about these before, they blew without having much on them. Have you checked the plug and it's wiring?
Old Jun 1, 2018 | 04:22 PM
Metricman's Avatar
The spark plug? I’ve checked the spark plug cable, but I haven’t checked the actual plug. As it’s firing up great. I’ve had the thing running for about 10min before killing it. Then the fuse was blown. This may sound stupid as I’m obviously no mechanic, but are you saying a dirty spark plug could blow the fuse even. I’ll try changing, this evening. I probably have a plug that will fit it.
Metricman
Jun 1, 2018 04:13 PM
tramar
Aug 13, 2013 12:43 AM
randymack
Dec 5, 2009 07:51 PM
Ruler
Jun 23, 2003 06:11 PM
bigrobzxxx
May 11, 2000 08:42 PM
