Need cylinder and cylinder head bolt torques
Old Jun 3, 2018 | 06:22 PM
Ehall8702's Avatar
Default Need cylinder and cylinder head bolt torques
2001 polaris scrambler 500 2x4. need to find torque for 4 bolts that hold the cylinder down and the torque for the 4 bolts that hold the cylinder head down. Been all over Internet and cant find the specs. Any help would be awesome thanx.
Old Jun 4, 2018 | 01:12 PM
850 trailrider's Avatar
Did this for my 04 500 Got this out of Polaris manual guess you need to do this for proper bolt stretch
CYLINDER bolts tighten in three stages crisscross pattern up to 46 ft lbs 2 smaller 6mm bolts 6 ft lbs
CYLINDER HEAD a little trickier here goes
criss cross pattern torque to 22 ft lbs
then torque to 51 ft lbs
loosen bolts evenly 180 or 1/2 turn
loosen another 180 or 1/2 turn
retorque bolts to 11 ft lbs
from this point tighten bolts evenly 90 degrees 1/4 turn
finally tighten another 90 degrees or 1/4 turn
install two 6mm bolts and torque to 6 ft lbs
note I'm not a Polaris mechanic LOL
Old Jun 6, 2018 | 08:31 PM
Ehall8702's Avatar
Default Thanx a lot man.
I sure appreciate the info, just bought one of the niche top end rebuild kits. Came without any paper work so I called a polaris powersports nearby and the mechanic gave me completely incorrect torque specs . So I get to do it again.
Old Jun 7, 2018 | 07:40 AM
Yup
cylinder is strait forward but cylinder head a little trickier bought a similar kit off ebay no instructions either but had Polaris shop man
Old Jun 7, 2018 | 07:51 AM
Ehall8702's Avatar
Default Yeah
I build car engines for a living so I figured itd be no issue, but incorrect torque specs will mess it up no matter what u do
hollowcd
Utility ATVs
11
Oct 28, 2005 10:05 PM
mountainclimber
Apr 24, 2003 10:20 PM
WarriorMan05
Feb 7, 2003 04:28 AM
Gen2
Oct 1, 2002 06:53 PM
