2006 Polaris scrambler 500 shifting problem
Old Jun 8, 2018 | 04:35 PM
Jgunner's Avatar
Default 2006 Polaris scrambler 500 shifting problem
Hey guys I was wondering if you could tell me anything about a problem I’m having with my scrambler 500? It always grinds into gear. If I start it and have it in neutral it grinds with a big clunk to get it in forward or reverse and I was wondering if anyone has had the same problem and how to fix it?
Old Jun 11, 2018 | 04:48 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
first thing you want to rule out is the clutch already tuning while in neutral from the belt being engaged. if so, then that's the major issue.
Old Jun 11, 2018 | 06:50 PM
Jgunner's Avatar
Thanks for replying. How would I check this problem and if so, what would I need to do to fix it?
Old Jun 11, 2018 | 10:57 PM
user493's Avatar
Moto Psycho
Take the clutch cover off. Put ATV in neutral. Start engine. See if driven clutch is spinning. It shouldn't be until you give it some gas. When you let off the gas it should slow to a stop.
Old Jun 12, 2018 | 03:35 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Old Jun 13, 2018 | 09:03 PM
Jgunner's Avatar
Ok I did this and they both turn in neutral. What can I do to fix this?
Old Jun 14, 2018 | 12:04 AM
user493's Avatar
Moto Psycho
Do you have the correct Polaris OEM belt? If not, get one. If you do, there are a couple of other things I can think of that could be wrong. Start with the simple thing first.
Old Jun 14, 2018 | 05:09 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
most likely if the belt is correct then the ebs bushing is gone in the primary clutch which was a common issue.
Old Jun 14, 2018 | 06:34 PM
Jgunner's Avatar
The belt is OEM. Do you have any other ideas?
Old Jun 14, 2018 | 07:26 PM
Jgunner's Avatar
Can you put a new bushing in? Or do you have to buy the whole thing?
