1988 300 Bayou
Old Dec 15, 2018 | 10:39 AM
bellefeuille26's Avatar
Default 1988 300 Bayou
Hello,
I Have an 88 300 2x4 Bayou. When I got this machine it sat for about 4 years.I have cleaned the carb thoroughly. It starts great and idles. When I punch the throttle it will bog. Is there only one adjustment on these carbs? Help please.....
Paul
Old Dec 15, 2018 | 12:20 PM
Kymco 450i's Avatar
Make sure airbox is sealed and no extra holes gave been added. Check intake boot to be sure no cracks or leaks. Might even try spraying some wd40 while it is running around the intake boot and see if engine changes speed. Otherwise it may be a clogged passage in the carb, most carb cleaning jobs dont get all the tiny holes cleaned out. Tiny wires are needed to open them.
Old Dec 16, 2018 | 09:39 AM
Thank you! I will try all these things. Paul
Old Dec 17, 2018 | 12:28 PM
How do you clean the 4 small holes at the bottom of the carb? Hard to get at.
Thanks Paul
Old Dec 24, 2018 | 07:17 PM
MrSummit's Avatar
desjardins2012
May 11, 2012 06:38 PM
steven07
Feb 18, 2008 10:56 PM
Ryanman01
Nov 25, 2004 01:13 PM
Ryanman
Nov 25, 2004 01:02 AM
