Sportsman 500 wobble/shimmy
Old Jan 15, 2019 | 09:34 PM
cbeckman58's Avatar
Default Sportsman 500 wobble/shimmy
2010 sportsman 500 HO
Replaced tie rods both sides and new ball joints. Also has brand new front tires (Carlisle at-489). Still has a bad wobble noticeable at about 35-40 mph. Gets worse the faster I go. Any ideas?
Old Jan 16, 2019 | 10:21 AM
polman500's Avatar
Have your new tires balanced.
Old Jan 16, 2019 | 10:23 AM
Kymco 450i's Avatar
Check for bent wheels, alignment might be way off, bad tire even though it is new. Set up on jack stands so tires can turn free and check to see if tires turn straight or wobble. My guesses...
Old Jan 16, 2019 | 12:17 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check wheel bearings as well but assuming you would have noticed a bad bearing when you did the other work. as mentioned put on stands carefully and let the tires turn to watch. bad wobe will knocked it off the stands so be careful
Old Jan 21, 2019 | 06:11 PM
Hammer Anvil's Avatar
Horn Hunter
Shake the steering wheel. If any play you may need to replace the steering bushing under light bezel.
rockout
Feb 8, 2009 07:27 PM
wolv99
Dec 4, 2002 07:14 PM
NANNIE
Oct 27, 2002 02:03 PM
smitty911
KTM
Mar 14, 2002 01:14 PM
Shadow
Mar 5, 2000 08:52 PM
