Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Valve timing
Old Mar 7, 2019 | 05:13 PM
Lestat997's Avatar
Default Valve timing
we have an old 2000 Yamaha breeze 125 that was blowing oil out the breather so we decided to tear into it and replace the piston and rings. Followed the service manual for it and completed the replacement. Now can’t get it to fire. We have compression, but wants to keep blowing gas into airbox out of carb. I set timing chain at TDC according to flywheel and can sprocket. When turning motor over with a socket and watching the valves, I have TDC set just before exhaust stroke, is this correct? Or should I do a 180 with it and set to just as intake is opening?
i did adjust valves while at TDC per manual specs. Not sure why I can’t figure this out, need some help here! I do have plenty of spark as well and newer carb.
thanks for any help
Old Apr 4, 2019 | 04:12 PM
Kymco 450i's Avatar
Do a compression test...if little or no comp your out a revolution.
Old Apr 4, 2019 | 05:59 PM
Lestat997's Avatar
I have great compression now, just went thru the carb completely, all clean. Spark plug isn’t even getting wet. If I hold my hand over the air intake of the carb I get a hand full of gas with plenty force...
bwiencek
Nov 15, 2023 01:46 AM
Heartnurse73
Oct 5, 2019 12:23 PM
prmazdarx7
Sep 27, 2006 11:03 PM
robnhouston
Jan 6, 2004 03:47 PM
mtecate4g
Jun 11, 2001 12:19 AM
