Clutch question for the experts
Old Apr 21, 2019 | 10:27 PM
oilcan1001's Avatar
Arrow Clutch question for the experts
I have a 2001 sportsman 500HO with EBS that I recently bought and have been trying to revive. Got it running well and then started having creeping issues. I removed the primary and took it to a shop to have it looked at and they tried everything but could not get it apart. Apparently it has seen better days.
So now, I thought about buying a new aftermarket clutch from Parts Ace, but would prefer to have a Polaris parts. Also I would like to change it to non-EBS and for this I would need a non-EBS secondary as well.
I have read that many different years and models can be interchanged.
So my question for the experts is what year(s)/model(s) with non-EBS will fit my machine ? (so I can begin searching for a used set on flea-bay)
If anyone has a primary AND secondary for my conversion I would be happy to purchase if the price is right.
Thanks in advance
Old Apr 22, 2019 | 07:20 PM
850 trailrider's Avatar
NOT AN EXPERT JUST TRYING TO HELP!
polaris non ebs primary # 1321976 just put in your 2001 500 weights and spring as far as secondary not sure if or what will Fit Sportsman if secondary splines same? believe they are.
I converted over my 04 Polaris atp 500 from EBS to I used 330 magnum primary [NON EBS] just put in my weights and primary spring [from ebs clutch] AND used a 2004 330 magnum secondary NON EBS and belt # 3211077 [ didn't change any springs on SECONDARY just replaced worn ramp buttons] maybe someone has suggestions for secondary? thought I heard you could use the old ebs belt on non ebs clutches but cant use standard belt on ebs ???
Old Apr 24, 2019 | 08:37 AM
oilcan1001's Avatar
Thanks for the reply 850 trailrider
fastasyoucango
Nov 5, 2003 01:01 PM
HOSPORTSMAN
Apr 3, 2003 02:38 PM
NewDSLover
May 7, 2001 09:33 AM
