03 trailblazer noise from rear
Old Jun 1, 2019 | 07:46 AM
Katherine22's Avatar
5 Year Member
Default 03 trailblazer noise from rear
Hi everyone- my 2003 trailblazer is making a weird sound from the rear right side. Like whoop whoop whoop. I just changed the rear bearings. The axel housing needs to be replaced. Where can I find one? Finding one has been a problem. Thank you!
Old Jun 1, 2019 | 07:50 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
First thing that sticks out to me is how loose that chain is.
Old Jun 1, 2019 | 07:58 AM
5 Year Member
I’m new to 4 wheeling so maybe the chain is too loose? I dont know
Old Jun 1, 2019 | 12:47 PM
Supersock
Hired Gun!
Yes, it's way too loose.
Hit it all with a hose and maybe we can see some other things.
We were all new to this at one time, so don't be afraid to ask.
Trying to find a Trailblazer service manual download. That will be a big help on working on it.
Old Jun 1, 2019 | 05:40 PM
5 Year Member
I’ll get better pics. Thank you!!
Old Jun 1, 2019 | 07:41 PM
5 Year Member
Hope these pictures help
Old Jun 3, 2019 | 06:48 PM
5 Year Member
Anyone out there?
Old Jun 4, 2019 | 06:33 AM
Supersock
Hired Gun!
Here's a pretty good tutorial on getting the chain tight. As loose as yours is, good chance of it coming off. As dirty as it was, you will want to clean it up, inspect it to make sure it has all the orings, and oil it up. Be sure to use a chain oil made for the orings. If you just use a lubricant like wd40, that is really bad for them.
Once you done that, see if the noise has gone away, changed or stayed the same.
Can't find a free service manual, but you can get a pdf download online. Depending on where you get it from it could be anywhere from 10-25 dollars. It's money well spent.
Old Jun 4, 2019 | 01:14 PM
5 Year Member
Awesome!!! I’ll get on that!! Ps...I know I need an axel housing because the diameters aren’t the same. The left bearing went in good. The right side was a pain because the diameter was too big and the bearing didn’t wanna sit quite right. I should probably do all this at the same time. Thank you!!!
Old Jun 4, 2019 | 11:39 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Should the chain be riding up the teeth where those wear marks are? I didn't have my Trailblazer long enough to know a lot about chain drives.
