Getting pipe what jet to use?
Old Apr 24, 2001 | 11:13 PM
bomberds's Avatar
I am getting a full system big gun pipe this week. I am also putting a k&n air filter on it. My elevation is 4500 feet what do you guys thik I should put it there.Big gun says a 170 main
Old Apr 25, 2001 | 12:12 AM
2000DS650's Avatar
Same question different exhaust....I am looking at the Custom X with a K&N, run at sea level to 3,500 feet elevation, what jet does everyone recommend? Shop manual says stock 2000 has 165 main.
Old Apr 25, 2001 | 01:41 AM
gpds650's Avatar
hey Bomberd,i got the same pipe,filter as you but got the lid of.Im riding between 5000 to 8000ft (elevation).I got the dynojet kit.main jet is 185,3 notch down from the needle.Its running excellent.i run race gas all the time 114 octane
Old Apr 25, 2001 | 10:42 AM
dskurt's Avatar
If you get a KN jet kit you get 7 different jets and good directions for different set ups. Also get needle and clip. And don't forget the all important stickers!!
Old Apr 25, 2001 | 12:40 PM
Knutz's Avatar
114 octane? Do you realize that with your motor, you are actually losing power by running that fuel? I didn't believe it either untill the folks at Dynojet Research showed me first hand with my own quad that had just a pipe and jet kit. I lost around 2 HP all the way across the rev range. The problem is that 114 octane fuel actually burns slower than a lower octane. It is designed to burn slower to control detonation in the high compression motors it was designed for. Drop back to 92 octane as long as your still running stock compression and you will regain that bit of power and save a bunch of money. This may be the only case in high performance that saving money actually increases power!
Old Apr 25, 2001 | 04:07 PM
Majorecho's Avatar
hey Bomberds, I'm just up the street from you and basically have the same set up - I too have found that the recommended settings from dynojet are as good as I been able to find with all my trials.
180 main and 3rd from top on the needle. Also I have the air/fuel screw turned in slightly more than recommended ( 1/4) turn and in the 0- 1/4 throttle circuit it makes more torque and wheelies are even easier from a dead stop in 1st and 2nd
Old Apr 26, 2001 | 10:27 PM
sand45's Avatar
DID YOU GET YOUR PIPE TODAY?????? LET ME KNOW IF YOU DID!
Old Apr 26, 2001 | 11:38 PM
2000DS650's Avatar
dskurt,
You said the K&N kit comes with 7 different main jets? What sizes are they? I was looking at that kit in the Rocky Mountain catalog but it didn't give any details. I emailed K&N and they never replied.
Old Apr 27, 2001 | 11:39 AM
ScoobyDFW's Avatar
I have found that Big Gun jetting is dependent on if you have the quiet core insert or the race core. With the race core you may want to go up in size on the pilot jet. For sure I would buy the dynojet/k&n power kit with the richer jet needle and main jets. If you have a 2000 model you may want to upgrade to 2001 carb specs.
Old Apr 27, 2001 | 06:41 PM
bomberds's Avatar
Hey sand 45 I got my pipe in last night. It is in awesome shape I put it on and it fits great. I am going to get it jetted tonight. Thanks for everything.
