T.B. Rear Shock
Old Oct 25, 1999 | 05:26 PM
Todd-007's Avatar
Has any one used a fox rear shock on there TB or went to a stiffer rear spring to keep from bottoming out on good sized jumps? If anybody knows where i can get a stiffer rear spring please post thanks alot Todd
Old Oct 25, 1999 | 08:41 PM
mac1181369's Avatar
You have probably already discovered this, but you can adjust the stiffness of the rear spring on the trail blazer by turning it.
Old Oct 25, 1999 | 11:31 PM
Todd-007's Avatar
I have it adjusted to the stiffest point right now but it just does'nt
seem to be quite enough though,Im 6 feet tall and 225llbs, any other ideas?
Old Oct 26, 1999 | 06:50 AM
Sburdman's Avatar
EPI (218-829-6036) sells a heavy duty spring for $19.95 and your dealer I belive can get one too. It should be about the same price, maybe less.
You might want to look at purchasing the Fox shock with reservoir that is in the Polaris accessories catalog. At $160 it will give you a better ride, a little more ground clearance in the rear and .6" more travel.
Scott.
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
Sep 9, 2015 10:56 AM
Jason Campbell
Sep 7, 2015 02:25 PM
Tim Shoe
Sep 7, 2015 12:15 PM
black_thunder
Sep 7, 2015 01:24 AM
