1994 Polaris 400
Old Sep 27, 2019 | 08:06 AM
Polaris4002stroke's Avatar
Default 1994 Polaris 400
Hello
I have a 1994 400 2 stroke that wont start , the starter solenoid by the battery just clicks when I try with electric start. Also when I try to pull over by hand, it pulls over very hard... and cant start that way either. Are you able to verify solenoid by jumping the terminals ? Could it be hydro locked with fuel in crankcase causing both scenarios ?
Thanks In Advance !
Old Oct 1, 2019 | 11:50 AM
pigseye's Avatar
Originally Posted by Polaris4002stroke
Hello
Thanks In Advance !
Yes, you can apply 12 volts directly to the starter to see if it actually works. If it kicks on you've confirmed the starter works and there is an electrical problem somewhere else that is preventing the starter from turning on when the ignition switch is on and the starter button is pushed. These starters are notorious for failing due to either water/corrosion or over use. Especially if the engine is hard starting then you are wearing out the starter.
Regarding: "Could it be hydro locked with fuel in crankcase causing both scenarios ?"
Was this ATV ever submerged for an extended period of time? If it was then it is possible. But in reality hydrolocking due to fluid in the crankcase is unlikely because it would take a lot of water or fuel (a quart or two maybe?) in the crankcase to cause this. Typically when seals for the water pump fail you fill the counterbalance oil reservoir with coolant not the crankcase. To check you can drain the crank case by removing the drain plug. Note that underneath the engine are 3 drain plugs. One is for the crankcase, one for the counterbalance fluid, and one for the recoil housing. You could unscrew the crankcase and recoil housing drain plugs to see if any fluid comes out. Do not unscrew the counterbalance plug unless you are prepared to replace the counterbalance oil.
Once you confirm if there was fluid filling the crank case, normal engine troubleshooting steps should be checked.
1) Is there spark? Check the spark plug while you're pulling the rope to see if you're getting an arc.
2) Is there adequate compression? Over 115psi will usually run well but I've heard of 400Ls with as little as 100psi that will still run but are tougher to start when hot.
3) Is there fuel? If the engine is firing but not running after squirting fuel into the carb then a clean and rebuild is in order.
Finally, you should be using a 40 to 1 pre-mix fuel during your trouble shooting phase because you have not confirmed that the oil injection system is working yet.
Good luck.
Last edited by pigseye; Oct 1, 2019 at 11:55 AM. Reason: Grammar and clarification of starter operation
Chappel
Apr 27, 2015 10:29 AM
jawbone
Sep 26, 2013 08:38 PM
OhioRon
Nov 11, 2010 08:21 PM
tmzg29
Feb 7, 2005 07:48 PM
