2) Chassis problems.. If your quad runs but you have other problems.. post in here.
110cc atv starts but won’t move
Old Oct 15, 2019 | 10:26 PM
Davidrbiking's Avatar
Default 110cc atv starts but won’t move
So my chinese 110cc atv with out reverse will fire up but when you press throttle it just revs up will not move need help I kno nothing about these things
Old Oct 16, 2019 | 02:41 AM
If you can't shove the bike by hand, the brakes are stuck. If you can, it may be anything in the transmission, but if it has a variator, the rubber belt will probably have broken. Other common problems are rear chain off the sprocket, or centrifugal clutch worn out. The bike usually moves with a worn clutch though, just not very fast.
Old Oct 16, 2019 | 06:14 AM
Yeah I can roll it fwd and bckwrd if jack up the back the wheels will spin but once they touch the ground it stops
Old Oct 17, 2019 | 02:45 AM
If you have checked the rear chain and it is OK, the only thing to do is remove the clutch cover and take a look at the clutch, or clutches.
Old Oct 17, 2019 | 06:09 AM
I got a new clutch on the way thank you for your help
xixi
Sep 17, 2019 09:08 AM
Dustinweed
Oct 15, 2016 02:06 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
