* Blasrer Light Problems*
Old Apr 25, 2001 | 11:19 PM
mud_devil's Avatar
hi my name is marc and i have a stock 98' blaster.
My headlights were intermitant and then stoped working all together. has anyone had this problem or knows how to fix it? please reply
Old Apr 26, 2001 | 12:13 AM
brokemybanshee's Avatar
It probally blew? They are easy to cook, dont know why... did you replace the bulb? If not, do it. If you did and it still does not work it has to be a loose connection or something, check for un-plugged wires. Good luck.
Old Apr 26, 2001 | 10:17 PM
Blasted's Avatar
My blaster has or had the intermitint problem but i could not find it,because when i get home and go to fix it i can not get it to go back out. it has not gone out for the last three months. if you fi
nd it let me know what is donig it. Good Luck!
98 blaster
dg nerfs
.20wisceo piston
Old Apr 26, 2001 | 11:54 PM
mud_devil's Avatar
i got some advise by an ATVing friend that is an electrician. he thinks it might be a wet charge coil or the main coil. it might also be the voltage regulator.
thanx for the responces
i will be updating this soon
Old Apr 26, 2001 | 11:55 PM
mud_devil's Avatar
oh... forgot to post... ALL of the lights went intermitant then dead, including the oil light, headlight and taillight
Old Apr 27, 2001 | 01:31 PM
exer's Avatar
Check the wiring connections to make sure they are tight. My kids blaster was doing the same thing, the connections on the wires were not tight causing intermittent loss of power/ground. plugged them together tightly and haven't had a problem since.
Exer
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
