Scrambler 400 4x4 not working
Old Nov 18, 2019 | 05:57 AM
John pendleton's Avatar
Weekend warrior
Default Scrambler 400 4x4 not working
Hi my name isJohn I have a 1998 scrambler 400 4x4 there is power in the switch and I have retired to get it going every thing is new and the coils are new but still not working
Old Dec 31, 2019 | 08:25 AM
wfburton159's Avatar
Did you get this working?
Old Dec 31, 2019 | 11:10 AM
Weekend warrior
Default Scrambler 400 4x4 still not working
I have a 1996 scrambler 400 4x4 four wheel drive is not working every thing is new but just can’t get it to work for me l have relocated the wires and put a new switch on it lights up on the switch and there is power going to the hub coils but it will not engage the four wheel drive
Old Dec 31, 2019 | 11:23 AM
Have you used an ohmmeter to check what the hub is reading? Both of my 2000 year hubs read 23 ohms when metering at the unplugged plug under the front hood. Does the reverse limiter work? My 2000 was not engaging 4x4 but did not have the light in the switch. From what I found on the wiring diagram is that the ground for the system comes from the reverse rev limiter module. I added a ground connection to the frame and all worked for me. Do you measure 12 volts from the wiring plugs to the hubs? If so that would eliminate the need for the additional ground.
Measure the ohms of each hub and confirm 12 volts from the plugs going to the hubs and probe the plug only. Do not connect common lead to the frame.
Polaris5004x4
Apr 12, 2014 01:21 PM
2000Polaris
Aug 10, 2000 12:32 AM
TRAIL
Jun 5, 2000 03:12 PM
