03 scrambler 500 4x4 not starting
Old Jan 1, 2020 | 04:03 PM
250 trailblazer's Avatar
Shadetree
Default 03 scrambler 500 4x4 not starting
My father in-laws bike got wrecked a few years ago and got forgotten in the shed pulled it out and cleaned the carb gas tank and fuel lines changed the oil and spark plug but can’t get it to start it turns over and backfires sometimes but with won’t start.
im no professional but I know enough to fix some stuff lol
Old Jan 3, 2020 | 04:19 PM
pigseye's Avatar
Welcome to the board!
If it is backfiring you know you're getting a spark which is good.
You probably need to rebuild the carb. If gasoline dried in there it is probably all gummed up. If it still won't run after a carb rebuild, check the compression.
Good luck and keep us posted!
Old Jan 3, 2020 | 10:53 PM
Shadetree
did that today now I definitely think it’s a hole in the piston or the valves gummed up because the stuff I found in the carb was no joke lol it was almost like old glue pretty nasty stuff gonna do a compression check hopefully this weekend and go from there
thanks for the reply 👍🏻
Old Jan 8, 2020 | 09:38 AM
pigseye's Avatar
Yeah, when gasoline dries up it can leave a nasty, gummy varnish. Before you go to far be sure to reconfirm that entire carb is clean and all the pilots and jets are truly clear and the float is set properly.
If compression is fine and you've eliminated all potential electrical issues the valves might need adjusting. Unfortunately, I am not an atv mechanic and most of my experience is on older 2 cycle engines so I am hoping some of the experts will chime in to help too.
Could you give us more info on the bike?
How long has it been stored?
What happened when it was stored? Was it an accident or a mechanical issue that caused it to be put away?
How many miles are on it?
This info might be helpful to others who respond.
Please keep us posted!
juniorlee
Jan 4, 2010 08:52 PM
Don4949
Dec 28, 2006 07:31 PM
grr86
Jun 11, 2006 03:03 AM
socri3allr
Mar 6, 2003 11:27 PM
polsrisracer2003
Feb 22, 2003 06:39 PM
