Compression
Old Jan 13, 2020 | 08:01 PM
CaseyC's Avatar
Default Compression
How far off can compression be before a bike wont start? My manual shows i should have between 80-120 with auto decompression engaged and I'm reading 90psi. My manual also shows if i back the exhaust valve out 2 turns i should have 180-215 and I ended up with 150psi. My first reading is on the low spectrum but within the range but second reading is 30psi short of the minimum. Would that be enough to cause bike to not start. Basics already covered, mechanical timing is good, strong blue spark, new fuel new plug. If I spray ether I get a hiccup but nothing promising.
CaseyC
Utility ATVs
Jan 7, 2020 10:10 AM
250yzFMXrider
Jul 13, 2008 01:49 PM
grill
Jan 7, 2007 06:45 PM
660rappy
Nov 20, 2003 07:10 PM
