1986 TRX125 ignition issue
Old Feb 16, 2020 | 10:59 AM
Bst's Avatar
Bst
5 Year Member
Default 1986 TRX125 ignition issue
Anyone know where I can find an ignition box for the 1986 Honda TRX125, for under a million dollars. Any diagnostic info would also be appreciated. It runs perfect for twenty minutes then no spark till it cools off, repeat. Thanks in advance.
Old Feb 17, 2020 | 03:03 AM
Although it is possible it is the CDI at fault, the usual culprits for this type of fault are coil, or stator, or trigger coil. Can also be fuel related, tank vent blocked, or running rich, etc. If you can, check for a spark when the fault is on. Change the plug too, it could be as simple as that. If you do need a new CDI, a modern Chinese 125 CDI could be made to work, but it takes an expert at CDI electrics to do it.
