Clutch Primary spring understanding
I own a 2011 Sportsman 400 HO, it has both the High and Low range forward gears. According to Polaris I have a Blue/Gray primary spring, which I believe has a rate of 0lb/30lb/170lb. My goal is more Low to Mid range pull (slower up-shift). Going off the information listed below, wouldn't I want a stiffer spring like a Dalton Amber DPPS-AM 10lb/73lb/189lb??? Any help understanding would be appreciated?
Going off of this information (gathered from a website)
Primary Spring Starting Rate = Controls Engagement
Stiffer Primary Spring Starting Rate = Higher engagement RPM
Softer Primary Spring Stating Rate = Lower engagement RPM
Primary Spring Ending Rate = Controls Up Shift, Back Shift & Peak RPM
Stiffer Primary Spring Ending Rate = Slower Upshift, Quicker Backshift, More Peak RPM
Softer Primary Spring Ending Rate = Faster Upshift, Slower Backshift, Less Peak RPM
Thanks, stendori. Something I need to keep in mind, I would probable sacrifice a few mph on the top end, to get what I want. I am also coming to understanding that it may take both spring changes, to accomplish what I am after. Anyone running the Polaris White Primary and the AAEN Blue Secondary? Or any other combination on a similar ATV? I have searched the forums for sportsman 400 spring setups, and most go with the Polaris White Primary and AAEN Blue. However, the previous year sportsman models use a different primary spring to begin with a Polaris Blue/Green with a rate of 0lb/10lb/110lb. So does that change my setup and results if I try to mimic it???
