2001 Honda Recon TRX 250 stuck in reverse
Old Apr 5, 2020 | 07:40 PM
Fireman8604's Avatar
Default 2001 Honda Recon TRX 250 stuck in reverse
Hello
i have a 2001 Honda Recon TRX 250 stuck in reverse it is not electronic shifting its Manuel shift with reverse button on hand brake. And it will start but you can not move shift lever up to go into neutral or through forward gears. Need help trying to fix it but no luck. I tried rocking it back and fourth while moving shifter that does not work either.
thanks
Old Apr 9, 2020 | 07:00 AM
Sounds like the selector mechanism broken. Remove the clutch cover and check. Usually the star wheel loose or a cracked/broken pawl or pawl lever.
daniel-delarosa
May 28, 2009 06:36 AM
Melton
Oct 22, 2008 06:03 PM
931oem1
Jan 15, 2008 11:48 PM
peteroakes
Jul 26, 2005 01:03 AM
pyromaniac442
Nov 15, 2000 11:57 PM
