Predetor 50 compression issues
Old Apr 5, 2020 | 08:16 PM
Camarojoe12's Avatar
Default scarambler 50 compression issues
Hey all, I’m having an issue with a friend of mines grandkids scrambler 50. He said it died and wouldn’t restart. I cleaned carb and changed plug got it going. But the throttle does nothing when pressed then eventually dies. So I checked compression and only read 30lbs. So I went ahead and tore it down and found the cylinder and piston were both scored. I replaced the cylinder and piston with new rings and all the gaskets including crank case seals. It still has 30lbs of compression. So I ordered another piston and jug kit just incase as well as new reed valve. Still has bad compression. I’ve tried 2 different compression testers and still very low and won’t get over 35lbs. Am I missing something? The only part I haven’t replaced is the head but it checked fine. I’m really stumped here. I’ve tried to test using electric start and kick while holding throttle wide open. Any help is appreciated
Old Jun 3, 2023 | 07:33 PM
scrambler50gguy's Avatar
Default Low compression
I realize this is an old thread, but did you get your scrambler 50's compression corrected? I have the identical problem with mine and have rebuilt the top end several times also.
Old Jun 3, 2023 | 07:34 PM
5point9
Apr 13, 2023 04:30 AM
Drosner
1) Engine problems..
Dec 2, 2018 09:01 PM
WolverineRdr
Apr 29, 2010 06:28 AM
02bigbear4x400
ATC 3-Wheelers
Aug 13, 2002 06:53 PM
Raptorrider2001
Dec 25, 2001 11:32 PM
