2007 honda trx 250ex
Old Apr 12, 2020 | 03:09 PM
Daunte Witcher's Avatar
Default 2007 honda trx 250ex
I went to go ride my quad today after replacing my rear bearing . For some reason it will not go past 3rd gear . Before it worked fine all the way up to 5, and it also goes in reverse fine. The only thing I did was tighten up the foot clutch lever on the left side . But I can't image that making it not go past 3rd. Any suggestions??
Old Apr 20, 2020 | 08:32 AM
Sheadog05's Avatar
Maybe try to loosen the lever again and see if that works. How much did you tighten it? Still, I couldn't imagine tighten the shifter lever would do that. Maybe you broke something coincidentally right after you tightened it?
Old Apr 20, 2020 | 08:36 AM
Yea Itried loosening it but that didn't fix it. I order new clutches, once they come in thursday I will replace and see if that fixes the problem.
Old Apr 20, 2020 | 10:18 AM
Sheadog05's Avatar
I am not the most experienced person in gearboxes, but I don't think this is a clutch issue. When you say you can't shift past third, does the shifter lever just not move up to allow you to shift? Or does the shift lever go up, but you remain in third gear?
Old Apr 20, 2020 | 10:20 AM
The shift lever goes up but it stays in 3rd gear.
Old Apr 20, 2020 | 10:26 AM
Update: I drained the oil out of the Gear Box and it was dirty slightly muddy like. I cleaned the inside, put fresh oil in and ran it again . It's ended up being able to go through all 5 gears and back down. Then I ran it again And it went through all 5 gears again but coming back down it will not go into neutral or reverse. I check the gear oil again it did not look too bad but I changed it again and still no luck.
Nikolas
Oct 20, 2015 03:26 AM
WishIhadaHonda450ex
Apr 8, 2006 10:46 PM
