2009 Polaris Sportsman Touring 500HO/EFI Overheating
Old May 17, 2020 | 09:55 AM
PAHoneypot's Avatar
Default 2009 Polaris Sportsman Touring 500HO/EFI Overheating
Need Help - I've recently purchased this Quad I took it out and after about an hour it would overheat, I first found that the previous owner used radiotar stop leak. Removed the old radiator, flushed the system, birped the radiator,removed waterpump housing and verified that impeller is in good condition and turns when engine is turned over, replaced radiator cap, replaced all fluids throughout, fan kicks on once up to tempature and at regular intervals or when needed, when it did overheat it overflows to expansion tank. I'm at a loss, please help thanks!
Old May 17, 2020 | 06:09 PM
Kymco 450i's Avatar
When the engine gets hot it is supposed to expand into the overflow tank. What makes you think it is overheating? Is the radiator boiling?
Old May 17, 2020 | 06:35 PM
PAHoneypot's Avatar
Yes the radiator does boil and the check engine HOT displays takes about an hour. Also worth mentioning I pulled out the thermostat to test in boiling water it did open and close, it opened about a 3/8 of an inch.
Old May 18, 2020 | 07:23 AM
Kymco 450i's Avatar
Did you use a thermometer to see at what temp the thermostats opened? When they go bad, they still may open but at a much higher temp...
Old May 18, 2020 | 01:03 PM
PAHoneypot's Avatar
No I didn't thought about it this morning so I decided to order a thermostat. We came to the same conclusion so that is a good sign. I will update once I receive and replace.thanks for your input and knowledge!
Old May 22, 2020 | 05:43 AM
PAHoneypot's Avatar
Update - Replaced the thermostat and no overheating. Thanks again!
stan5686
Oct 20, 2017 12:27 PM
DODGE57HEMI
Dec 16, 2009 10:16 AM
STLcardinals24
May 9, 2009 02:49 PM
2009Razor
Polaris Side by Sides
Nov 27, 2008 01:48 AM
