Thermostat modified
Old May 22, 2020 | 07:46 AM
DavidO.'s Avatar
Default Thermostat modified
Was wondering if I modified the thermostat to allow coolant to always flow will that hurt or help.
I'm on 2004 polaris 700 sportsman twin.
Old May 25, 2020 | 08:56 AM
Nomicron99's Avatar
Bad idea! Thermostats are designed to keep your engine running at the desired temp but that also have a side effect. It allows the coolant in the radiator to cool down. If your over heating then your radiator might be plugged or fins clogged.
I would check that first. Make sure its clean and flowing good. After that i would try a new thermostat and after that the water pump. All this assuming your full on coolant.
AZBanshee01
Jul 26, 2012 11:13 AM
steve83070
Utility ATVs
Mar 4, 2009 04:44 PM
pg_etrn
May 20, 2008 08:39 AM
got2gofast
Apr 17, 2005 01:15 PM
