Technical and How-To Articles Post your Tech Tips and How-to articles here. Photo illustrations welcome
Arctic Cat 250 melted wires!
Old May 27, 2020 | 12:35 PM
Chuckin's Avatar
Default Arctic Cat 250 melted wires!
So unfortunately I wasn't home when my 250 went up in smoke. My teenage son was riding, says it started bogging down as if it were running out of gas. Then he saw smoke and turned it off. Upon inspection, the coil is split in half as if something expanded inside and cracked. Multiple wires are melted together, including the plug that goes to the top of the starter relay. What may have caused this? Also, the wiring harness is quite expensive. I figured I could replace most of it myself. But for one, I can't find the plug itself without buying the whole harness. Plus, I can't really tell what gauge wire was used. The green ground wire is intact, for the most part the 2 black wires on the relay plug are what's compromised. What gauge should be used? And if I can rig those wires and replace the coil, could I be in for a reoccurring underlying problem? Any advice would be much appreciated! Thank you
Old Mar 23, 2023 | 04:10 PM
Kylejpeck's Avatar
Hello, I was wondering what your solution was to fix your melted wire issue on your artic cat 250? I have one also and had the same wires melt on mine. I’d like to talk details with you about it if we can somehow? Thanks, Kyle
supermanotorious
May 17, 2015 10:39 AM
May Stickman
1) Engine problems..
Jul 7, 2012 11:14 PM
tex599
Feb 21, 2011 11:25 PM
chinqmasta
Jul 17, 2010 04:34 PM
bash
Mar 16, 2000 11:14 AM
