LT80 shuts off when hot
I recently purchased a 1996 LT80. The previous owner had it for a couple years for his son to learn to race on. It appears mostly stock except for a DG pipe and speed gearing kit. He did say that he recently put on a new carb. It starts up and idles great. When my son is riding it, it runs good for about 5-10 minutes and then it begins to lose power then just dies like ran out of gas. After a while it will fire up and run for a minute or two and does it again. Although yesterday, I could not get it started again. I have read on here about the petcock issues so I did purchase a banshee petcock but haven't installed it yet. I did also check the compression and it was 120 psi. The first time he rode it I noticed the oiler line had popped off but it was only off for a couple minutes before I noticed it and put it back on. I was hoping it didn't screw anything up and that's the main reason I checked compression. Could it be a coil/cdi issue?
Hi LT80, thanks for the reply. I did install the banshee petcock this weekend and it ran good for quite a while with out shutting off but the kids never ran it hard so not sure if it got hot enough. Going to run it a little harder this week to test it out. It does have trouble pulling the kids up hills so I think I may need to look at the clutches. When they are shut off, should they roll freely? This one has drag to it and there is a grinding/gripping noise coming from the clutch area. Thanks for your help!
Hi LT80,
I put the banshee petcock on it and it doesn't shut off anymore. But what it does now is when he runs it hard for about 5-10 minutes, it looses all power and will not even pull its own weight. If I lift the rear end off the ground it winds out and runs good. But under load it has no power. I let it set for about half hour and once it cooled down it ran decent just around the yard putting around. Any idea what could be causing this? Thanks
I will try a comp test this weekend after if gets hot. Also need to check out the clutches too as you suggested. It still has automatic oiler on it and when I pull the line a little drop comes out every couple seconds while it is sitting still running. Does that sound like enough oil? Thanks for your advice!
