Used 110cc taotao problems
Old Nov 13, 2020 | 06:50 PM
Dumby286's Avatar
Default Used 110cc taotao problems
I just got a used 110cc taotao that has been sitting for a few years. I was getting zero power anywhere til I replaced the key ignition and now I get the neutral light on.
I cant get it to crank with the button ignition. If i jump the starter relay the starter cranks but i get nothing with the ignition button.
I have replaced the starter relay, battery, key ignition.
Thanks for yalls help
Old Nov 14, 2020 | 02:49 AM
On most quads there is a lock-out so either the brake light has to be on, or the gearshift (if fitted) has to be in neutral, before the starter will work. Even if you are doing this, the switches for them may have corroded so check this first. As you are getting the neutral light, that switch is OK but wire between switch and starter solenoid may not be. Some kids quads also have a remote, this can go bad and interrupt the starter circuit as well. It may just be the starter button corroded after the lay up. Best way is to follow the thin wires back from the solenoid, checking as you go, one should be pos with ignition on and start button pressed, the other negative, one will be, so the other is the faulty wire, trace it back to the fault.
Old Nov 15, 2020 | 01:59 PM
Dumby286's Avatar
Thank so much.
It was a bad brake switch.
Wolfekevin
Dec 31, 2016 12:54 PM
RayRay711
1) Engine problems..
Dec 22, 2016 06:22 AM
stephers618
May 3, 2015 09:04 AM
b_ryan1978
Jul 5, 2014 06:54 AM
nike4life
Aug 13, 2010 08:37 PM
