Xtreme Machine x90 2 stroke. Has spark but not turning over. New wiring harness
Old Dec 12, 2020 | 09:39 PM
Michael Schalk's Avatar
Default Xtreme Machine x90 2 stroke. Has spark but not turning over. New wiring harness
Bought fixer upper for kids for Xmas. The quad didn’t run when I bought it. I need some help getting it started. I feel like the kill switch is on bcuz it sparks good.
Old Dec 14, 2020 | 03:12 AM
Sorry but your description is all over the place, it must "turn over" or you wouldn't be able to check for a spark and if the kill switch was on there would not be a spark, as that is what it does, kills the spark. If it has a spark, and turns on the starter, it may need the carb cleaning. If it has electric choke, is that wired in correctly? Or it could have a worn cylinder, this can be checked by a compression test, much under 90psi and it needs the cylinder removing to check for worn rings, and/or cylinder, blown head gasket etc.
Hunter34
Sep 16, 2019 01:47 AM
Michael Seneff
1) Engine problems..
Mar 16, 2019 07:11 PM
Davidinkinc
Jan 9, 2016 05:42 PM
Hjwray
Oct 23, 2012 11:54 PM
