Chinese quad help
Old Dec 28, 2020 | 09:11 AM
JokersWarrior420's Avatar
Default Chinese quad help
Any help. I disconnected the key and multi switch at the plug. I used a screw driver and got it started at the starter solenoid. Ran good idle but would die with throttle. Anyone know what it is. Only thing I can find is that it has gy6 shrt case engine. With forward, neutral, reverse.
I took this off from the white plug
Old Dec 29, 2020 | 04:08 AM
I doubt if your running problems are electrical, but get the correct key switch assembly, I guess Extreme Motorsports will have them in stock. Clean the carb out and fit a new spark plug, which should cure the running problem, unless you have messed up the wiring of the electric choke mechanism too.
JokersWarrior420
Dec 28, 2020 09:02 AM
Victoriscool
May 18, 2020 10:09 AM
Daverr
May 10, 2020 04:59 AM
Hunter44
Sep 22, 2019 02:45 PM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
