2006 polaris EFI
Old Feb 13, 2021 | 07:39 PM
dcerch's Avatar
Default 2006 polaris EFI
Hey guys I have a 2006 sportsman 500..new battery new solenoid when I turn the key the headlight comes on and the speedo blinks i also hear a sound that sounds like a fuel pump. When I turn the key to start I get nothing if I jump the solenoid the engine turns over but no spark . I have power to the cdi going in and coming out and also to the on off switch which is also new...can someone please help .
Old Feb 14, 2021 | 07:23 AM
Powerranger262's Avatar
By "on/off" switch, do you mean the key, or the left hand kill switch? I had a no power issue with mine, and turned out to be the kill switch. If you know someone with a similar running machine, you could swap it to see if that is an issue.
Also, check the throttle cable safety switch. Open up the little cover by the throttle lever. I forget exactly what it looks like in there, but there are some points that close, and shut the machine off. A quick youtube should pull up a good video.
Old Feb 14, 2021 | 07:48 AM
dcerch's Avatar
Hi , I am referring to the on off switch on the left handle bar or the kill switch..I purchased a new one and i have power there and it seems to work fine.. but I willbtrwill try the throttle cable safety and see if that may be the issue.
thanks for your help I will letbyoulet you know what I find.
Old Feb 14, 2021 | 10:00 AM
Here's what I'm talking about.
Old Feb 15, 2021 | 11:16 AM
dcerch's Avatar
I removed the cover and the gap is fine it doesn't seem like that is the issue.
lindy161998
1) Engine problems..
8
Jun 9, 2021 09:21 PM
Bighollander
Aug 3, 2019 08:27 PM
Steven1010
TheATVSuperStore
Apr 27, 2017 10:03 AM
sreeve2591
Jul 31, 2008 03:55 PM
Bookwork90
Mar 5, 2008 06:24 PM
