Wheel swap
Old Feb 25, 2021 | 07:05 PM
Jeromy Edwards's Avatar
Default Wheel swap
I have a 2020 Polaris sportsman 450HO with 24x10-12 and I bought some tires and rims off of a 2015 Polaris sportsman 1000xp that are 26x11r14. The rims do not seem to fit. Is there a right way to make it work?
Old Feb 25, 2021 | 07:25 PM
Kymco 450i's Avatar
25x10x12
the first number is the od of the tire, the second number us the width of the tire, the last number is the rim diameter. In your case you had 12" rims and bought 14" rims
Old Feb 25, 2021 | 07:54 PM
Default Hi
I understand that part. I bought tires and wheels already mounted and doesn’t seem to fit my hubs. Thinking I might need a spacer or adapter?
Old Feb 26, 2021 | 07:28 AM
FlawleZ's Avatar
Classic Yamaha Fan
Have you tried all 4? The Sportsman 1000 should be 4/156 bolt pattern like your 450 HO. Are you sure that's what they came off of? Are you sure the 1000 didn't also have adapters? It's possible the 1000 they came off had wheel adapters to change the bolt pattern to match the wheels.
cwlongshot
Feb 27, 2011 01:56 AM
rcntc2009
Mar 16, 2009 03:57 PM
BOOBEAR
Jan 12, 2005 05:39 AM
J.C.Baloun
Apr 12, 2000 04:45 PM
