84 Honda ATC 200M won’t downshift into 2nd
Old Mar 27, 2021 | 10:33 PM
mjhorning's Avatar
Default 84 Honda ATC 200M won’t downshift into 2nd
Hello,
I acquired an 84 Honda 200M today and am having problems shifting. Right now I have it up on blocks and bypassed the neutral switch so I can use the electric start. It took some carb cleaning and electrical fixes but it sounds great.
The problem now comes to the transmission. I can shift the transmission between 3rd, 4th, & 5th with no problem, but I can not get the trans to shift any lower than 3rd. Any thoughts on how to fix that?
Old Mar 28, 2021 | 02:11 AM
If the clutch is working properly, your problem is going to be the selector mechanism or the gears themselves. All you can do is remove the clutch housing and take a look at the selector mechanism. If there are no obvious faults, e.g. a loose star wheel is common on Hondas, it is deeper inside, so the selector forks and gears will have to come out.
Old Mar 28, 2021 | 07:30 AM
mjhorning's Avatar
Ok, I’ll have to dig into it more tonight
mmumm
ATC 3-Wheelers
Jan 10, 2016 06:15 PM
runaway
Jul 6, 2008 12:05 AM
honky
May 31, 2005 10:57 PM
KingQuad0014
Aug 17, 2001 05:37 AM
