02 ds650 piston issue
Old Apr 6, 2021 | 04:52 AM
Lucas Hoxter's Avatar
Default 02 ds650 piston issue
When I turn the crank it stops at tdc, and If I turn it the other way in will stop at tdc but won't rotate past tdc. What should I do? Take it apart?
Old Apr 9, 2021 | 03:28 AM
Yes, take head off and find out what is going on. My guess is something fallen into cylinder. Check the cam timing too as, if timing has slipped, the piston could be hitting a valve, if so, the valve will be bent.
rajaa11
May 16, 2007 10:28 PM
