Atv won’t crank
Old Jun 27, 2021 | 11:29 PM
Amflore's Avatar
Default Atv won’t crank
Bought atv was working fine now won’t crank i purchased a new starter and for some reason it melted the starter when I tried cranking it don’t know what it could be any ideas ?
Old Jun 28, 2021 | 01:46 AM
First find out if the crankshaft is free to turn by removing the spark plug, taking a case off and turning the crank by hand. If it is, check you got the right starter. The one for 50cc Honda clone engines isn't the same as the one for 90cc Honda clones, or you may simply have got a dud new starter.
Old Jun 29, 2021 | 01:46 PM
Amflore's Avatar
starter overheats by itself when connected under no load
Old Jun 29, 2021 | 01:47 PM
Amflore's Avatar
Is it normal for the starter to have case continuity ?
Old Jun 30, 2021 | 01:46 AM
There is a small resistance through the starter armature windings, but not much. It will get hot quite fast as it is only supposed to run for a few seconds. However, if it is definitely overheating without being attached to the starter gears there is something wrong with it. Take a look inside. Most common fault is the earth side brush lead not being tightened down.
fixitmom
Jul 18, 2019 08:26 AM
dbarr34
1) Engine problems..
May 25, 2018 01:23 AM
jontavian16
Mar 29, 2018 07:40 AM
