2004 Arctic Cat 300 Won't Rev
I have a 2004 Arctic Cat 300 ATV 4x4. Recently, it lost of significant amount of power. Started and ran fine, but just did not have high end torque like it used to. Engine did not cut out or sputter, just little high end power. Revved ok in neutral. I checked compression and it is well within spec (175 PSI with throttle wide open). So I decided to clean the carburetor. Removed all jets and such, sprayed with carb cleaner and blew out with compressed air. Put it back together and reinstalled. Now engine starts fine and idles great, but as soon as I start to open the throttle the slightest bit, it dies. I've tried adjusting pilot screw all the way from about 1.5 turns to 3 turns and no change. Took it back apart. Tiny washer and rubber o-ring at base of pilot screw went missing. I must have blown them out and did not see them. So I bought a kit and installed new ones. Still the same problem. Jets all seem open. I can see daylight through each of them. Still starts fine and idles fine, but just won't let me open the throttle the slightest bit without dying. I am out of ideas on what to look for. Any help will be greatly appreciated.
Carb system - Float level?
If you can, push (or jack) ATV's front wheels on a 6" high block and try reving engine again. Then, push (jack) ATV's rear wheels on a 6" high block and rev engine again. If change in engine behaviour when engine is tilted, then its probably from float level setting.
Hope this helps....
Hope this helps....
I have a 2004 Arctic Cat 300 ATV 4x4. Recently, it lost of significant amount of power. Started and ran fine, but just did not have high end torque like it used to. Engine did not cut out or sputter, just little high end power. Revved ok in neutral. I checked compression and it is well within spec (175 PSI with throttle wide open). So I decided to clean the carburetor. Removed all jets and such, sprayed with carb cleaner and blew out with compressed air. Put it back together and reinstalled. Now engine starts fine and idles great, but as soon as I start to open the throttle the slightest bit, it dies. I've tried adjusting pilot screw all the way from about 1.5 turns to 3 turns and no change. Took it back apart. Tiny washer and rubber o-ring at base of pilot screw went missing. I must have blown them out and did not see them. So I bought a kit and installed new ones. Still the same problem. Jets all seem open. I can see daylight through each of them. Still starts fine and idles fine, but just won't let me open the throttle the least bit without dying. I am out of ideas on what to look for. Any help will be greatly appreciated.
carbs are bad for that .
rebeltaz
Nov 18, 2020 09:17 PM
Big Boys Big Toys
May 13, 2013 03:56 PM
