2004 Polaris 500 ho won’t start
Old Oct 23, 2021 | 02:51 PM
Heyit’sjesse's Avatar
Default 2004 Polaris 500 ho won’t start
Pretty much what the title says. The electric start won’t work. It worked fine one day, then the next, nothing. I’ve replaced the starter solenoid. If I touch both terminals together, it fires right up. I replaced the ignition switch, and that wasn’t it either. Had the battery tested, and it’s fine. It pull starts on the first pull, but I get nothing when I turn the key. No clicks, nothin. Any ideas?
Old Oct 30, 2021 | 01:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did check the in line circuit breaker(wire harness) to make sure it wasn't tripped? I'm just assuming it has one with out taking the time to look it up. check the connections for corrosion and puts some di-electric grease on them. just an idea
jakenate
Jan 22, 2020 03:33 PM
marsh_huntr
Aug 21, 2011 05:25 PM
ukfan041
Apr 8, 2010 09:02 AM
Lat22
Oct 31, 2008 10:26 PM
polaris 700 IQ
Jun 4, 2008 06:22 PM
